dax winwarbler 6300 which channels
Lewis Cheek
I'm moving forward (snail pace) with learning to use features of the FLEX-6300, however this DAX thing is a bit confusing for me.
Appears that software loads channels that are not usable for the 6300 as it only has two channels.
What are the DAX channels used with the 6300, and how does one remove ALL the extra channels with Windows 7?
I'm attempting to set up Winwarbler as DXLAB Suite is my default logging software.
73's
Lew
N4CO
73's
Lew
N4CO
Because I use 4 VAC channels, I couldn't keep all the DAX channels that were created.
Simple go to Windows Sound settings and delete a pair or two.
WinWarbler will only accept a total of 8 or 10 in and 8 or 10 out channels and DAX will overite them some of the VAC. At least it did for me. Deleting some of the DAX you won't use fixes this issue.
Then I think you select in WW which in and which out pair you wish to use.
I'll give that a LOOK.
73's
Lew
http://sdr-w9oy.blogspot.com/2014/06/digi.html I set mine up like this 73. W9OY1
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
