Flex 6300 with SSDR 1.2.1 continuos scanning
Welcome!
  • Community Manager admin
    edited February 2017
    The microphone that ships with the radio has up/down buttons.  If one of these is stuck, the radio will scan.  Try pulling the mic out of the connector to split the problem between the mic and the radio.  If it continues after you pull the mic, please enter a help desk ticket and we will contact you to work through the issue.  A rare condition with the ESD diodes on the the mic up/down input lines can cause this problem also.
  • edited March 2015
    Hello Steve
    thanks for reply , the defect remains the same with and without the microphone connected.
    I will contact the help desk.
    73 Franco  I6QFZ
  • Administrator, FlexRadio Employee admin
    edited March 2017
    This topic has been transferred to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
