PowerSDR DSP-NR
Kuby, N6JSX
Are there DSP-NR & ANF settings that really work?
I've been trying to get NR set to work as good as my IC-7K/IC-746P and it is totally apples and tomatoes. My IC's NR works so much better in eliminating background noise and pulling weak SSB signals up/out that PwrSDR just cannot parrot. Woe be it if I run both NR & ANF on F3K - the SSB audio becomes highly attenuated, distorted, garbled.
Since I cannot find the right settings I consider this a BUG in PwrSDR w/F3K.
NR/ANF Tap/Gain/Delay are explained but 'Leak' is no where to be found in the current manual.
Adjusting the AF/AGC-T helps considerably but what a fine line to walk.
you get them too work let me know
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
