DAX audio 2 not assigned to slice 2
W9OY
I set up rtty last night and thought I'd try the Stu K6TU method of split which requires DAX transmit audio on channel 2 (slice
. I looked at DAX control panel and see channel 2 is not assigned to anything
How do I make channel 2 assigned to slice B? 2 is chosen in the second slice under the flag in slice B
73 W9OY
73 W9OY
Is DAX set to channel 2 in the Slice B control panel (flag)?0
Yes0
You can see this if you look at the channel 2 I/q. The 2 i/q is connected0
Check to make sure Windows hasn't done something nutty like grabbed the DAX channel as the default sound device.0
DAX IQ audio is sourced from the panadapter. Adio stream DAX is sourced from the slice receiver. Looks like you have two panadapters open and each one assigned to DAX IQ.0
I guess how you check that is to click the speaker icon in the tray? The only thing that comes up is the speaker.0
I figured out how to check speaker is the default device0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
