Firewall Question: 6 listings of SmartSDR v1.2.1
Bill-W9OL
On my HamRadio 'ONLY' computer, when checking something else, I found 6 (SIX) listings for: FlexRadio Systems SmartSDR v1.2.1. Is this normal? Pretty sure I only installed it ONCE.
All 6 are enabled for both Home/Work (Private) AND ALSO for Public.
This is normal. Windows has 3 different Firewall profiles and SmartSDR has two (2) firewall rules for each instance of the application (one for UDP and one for TCP).0
And following up Tim, I have listings for:
4 listings for
FlexRadio Systems SmartSDR v1.21
and 4 listings for
FlexRadio Systems SmartSDR v1.217
Should I? or CanI? delete the v1.21 listings (leaving the newer version?
or should I leave well enough alone?
Times like these, I've always found that "if it ain't broke, don't fix it until it is" are pretty good words to live by.
In general, I do not advocate messing with the Windows Firewall. The extra entries should have been removed when you uninstalled SmartSDR v1.2.1, but the uninstaller relies on Windows scripting and that isn't always 100% reliable. They will not hut any thing by being in the firewall rule set.0
makes sense. I have a neatness issue, I 'suspected' that that was the result of previous upgrades.
I've been having a wee bit of trouble keeping PSDR tracking WSJT-x and thought a house cleaning may have been in order.
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
