Flex 5000A Power Speaker Output Jack Intermittent
This jack has become very intermittent.  Before I open up the radio, is there a part number for this?  Can the part be purchased from Flex?  Right now it's working with a bit of DeOxit and just the "right" position of the plug from the speakers.
  • Tim - W4TME
    edited March 2017
    I would submit a HelpDesk support ticket if it becomes problematic to triage the issue and evaluate your repair options.
  • N5LB - Lionel
    N5LB - Lionel Member
    edited August 2016
    Thanks Tim, will do.  I did note after pouring thru docs that it is a CUI SMT 3.5 mm  jack.
