Loud TR Relay
K5FM
While the PIN diode/reed relay TR system used in the CW QSK mode is reasonably quiet, the click/clack of the TR relay when in SSB mode is very annoying. At first I assumed this was some type of amplifier keying relay that could be disabled, but that does not seem to be the case. Why can the same TR hardware used in QSK not be used in other modes? If it is a function of obtaining the ultimate in noise floor we should at least have the option of choosing a silent TR mode over noise floor if that better suits our operation. All of my amplifiers use either vacuum relays or PIN diodes for TR switching, and all of the other premium transceivers I have owned over the last 25 years could be configured for silent TR switching, this is a huge step backwards and would have been a deal killer had I known about it before my purchase.
PIN diodes introduces transmitter IMD on linear modes like SSB. It would be technically possible to use the PIN diode in SSB on the 6000 series but at the expense of linearity, which does not matter on CW.0
?, PIN diodes are the industry standard for RF switching where linearity is a critical requirement. In my work we have been using them for over 25 years in applications where linearity requirements far exceed that required of a amateur SSB transmitter, with proper biasing IP3 performance should be down to the level of a mechanical relay.1
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
