Cat connection from 6300 to my logging software LOG40M
howard krawitz
I just purchased and installed a flex6300. The procedure to work with CAT systems for the FLEX is to first install SmartSDR CAT. In doing so the program identified the following:
to connect to com port 4. My next step was to load OmniRig and make the COM PORT 4 into RIG2 which is the OmniRig selection for Log40m. The only problem is you don't have a selection for the FLEX 6300. I spoke with Flex and they suggested either TS-2000 or PowerSDR, which is there old software. In either case I could not get it to work.
Please advise what I need to do to connect your software to my FLEX. Still having problems. If someone out there has solved the problem please feel free to contact me to resolve the issues.
Howard Krawitz
AH6TX
gvm920@gmail.com
661-821-
Howard Krawitz
AH6TX
gvm920@gmail.com
661-821-
Try a different program, like Fldigi running RigCAT to verify the CAT connection is working since there isn't native support for SmartSDR with Omnicat. There is a SmartSDR.xml file for RigCAT.0
My guess is the Flex Control owns com 4. Sometimes SmartCAT ain't so smart and will try to create a virtual port on the Knob port
I use DDUTIL v3 for SmartCAT to omnirig If DDUTIL is not connected to CAT then connect it using that choice under options. Make sure SmartCAT is running as well sometimes it crashes and needs to be restarted.
Once you install DDUTIL it should connect to SmartSDR via smartCAT. Make sure signature is chosen in the DDTIL setup > Features
Next use SmartCat to create a shared port My omnirig>DDUTIL is on 5,15. Check in the windows device manager to see your ports are active (Just type device manager in search to get there)
Set up port 15 in DDUTIL>setup>ports or whatever port pair you choose. I always put the higher port of the pair in DDUTIL
Set up port 5 or the other half of your port pair in Omnirig 1 and choose powerSDR
Setup Log4OM
Drink some coffee and work some DX Make sure Omni rig 1 is chosen on the main screen of Log4OM. As long as SmartCAT is running and DDUTIL is connected to it log4om should work FB. Very occasionally you might need a reboot if the ports aren't there.
73 W9OY
I want to thank w9oy and all who responded the addition of DDUTIL etc is making it work. My understanding is we need to keep CAT open. Do we need to keep ddutil and OMNIRIG open as well. Right now the only thing open is the CAT. Let me know
Thanks again,
Howard
PS If I can be of further help let me know.
ddutil stays open I think omnirig is started by log4om0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
