F6300....Key (CW) from the rear, instead of the front?
W4TMW
W4TMW Member ✭✭
edited January 2018 in SmartSDR CAT
Is there a way to run my keyer (Brown Bros)...or straight key, from the 6300's rear panel instead of the front?
Thanks, Tom
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    Yes, you can wire it into the accessory jack on the rear.  It is the DB-15 connector.  I don't remember the correct pin out but look at the Flex 6000 hardware manual on the web site.  73s Jim K4JAF
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    Tom,
      On the ACC connector Pin 4 is CW KEY/FSK/INT... Pin 5 can be used as ground..
    AL, K0VM
  • Scott AC8DE
    Scott AC8DE Member
    edited June 2014
    Holy Cow Batman!  I didn't realize that the whole time.  So I can use my external keyer and plug my iambic paddles into the keyer and wire that into the DB-15.  Nice.
