memories in SmartSDR
Nick - W2NER
memories in SmartSDR? I just got my 6500 today and I have looked over the manual and i don't see anything about saving memories (For freq, band, mode and so on) anyplace. Am I missing something or was this basic feature left out along with the FM mode.?
2
Sorry nic no memories yet. You can get the iPad app and it will allow you to create memories.0
Which app is that?0
I understand this is a coming feature, correct?0
The "persistence" feature will remember the last settings on each band you use, so it's kind of like having memories. Pretty convenient. My logger (MacLoggerDX) has full support for creating and using memories - other applications may have similar functions.0
I don't know if this is what you mean but this is what I use
http://sdr-w9oy.blogspot.com/2014/06/k9dur-sdrmemory6k.html
73 W9OY0 -
That looks like it however it does not look like supports the flex 6000 series. I installed this and could not get it to communicate with the flex 6500 and many buttons were missing like scan for example. The only menu buttons shown was exit, favorites and add.0
Nick, in the link Lee posted, it shows photos of K9DUR's "SDRMemory 6K" working directly with a 6000 series radio (which is why it's name includes the 6K moniker...hi hi). I hope you get it working!0
That's true, my bad. Strange, this should be straight forward but, I'm doing something wrong. Oh, I should mention I'm running on Parellels on a IMAC27.0
Just reviewed his link and his install looks like mine, he does not have the buttons as well. So, mine seems to be setup like his but when I select a favorite nothing happens. I have a feeling I have the CAT setup wrong or something along those lines.0
You may need to set up another dedicated virtual serial port using sdrCAT. And link it to that port.0
Thanks to all! I got it working... ;-)0
I have the FLEX-6500 too. Has anybody heard WHEN memory channels will be added to SmartSDR as well as HOW MANY channels will be supported? As a disabled ham (semi-quadriplegia) due to a terminal illness called MELAS (http://emedicine.medscape.com/article/946864-overview) would make this feature a BIG help to my operations. Like this morning, due to the "E" in MELAS, I could not remember the frequency of a net that I am on every day. A memory recall feature with net names would have eliminated that issue. As for the number of memories, 250 would be "nice" but variable arrays from 10 to 1,000 would be even better. Tnx es 73, Dave K4EET
P.S. Will I automatically receive updates to this post or do I need to check back in periodically? (Newbie user to the community...)
I think updates come to you if you are part of a thread, but checking back is what makes us a community. Welcome to Flexland
What you want is practically available using K9DUR's free memory program
I describe how to get it and the way I use it in my blog
it can be expanded to as many memories as you are likely to need and each memory has its own label and can be grouped however you like. I run my SDRmemory6k through DDUtil to the radio
73 W9OY
Thanks Lee! I'll check it out... 73, Dave K4EET
Lee, that link takes me to:
K9DUR Voice Keyer
(Version 5.2.1)
I don't think that is the correct program...
73, Dave K4EET
Scratch that. I clicked it a second time and got the correct page. Not sure what happened. 73, Dave K4EET
Lee, it's your BLOG that has the WRONG link. Needs to be fixed... 73, Dave K4EET
Your blog for SmartSDR should point to:
http://k9dur.rnaconsultingservices.com/smartsdr_utilities.html
Thanks David I updated0
Yes, this program works well I the interim, but you must program the frequencies manually. It is nice to have about 40 memory buttons for my 6500!0
- 113 SmartSDR+
- 920 Genius Products
