Documentation for two types of UDP broadcast discovery protocol?
Steve Conklin
Steve Conklin Member ✭✭
edited February 2017 in SmartSDR API
On the network, I see that there are two different UDP broadcast packet types for radio discovery. Is there documentation for both of these packet structures?
  • Eric-KE5DTO
    Steve,
    If you are writing a new parser, I think you just want to handle the newer protocol which is described here: http://bit.ly/1jRbU5q.
    (link updated)
  • Steve-N5AC
    Steve-N5AC Community Manager admin
  • Steve Conklin
    edited July 2015
    Thanks Steve, It's all clear now. That matches the packet data I see. I has seen that previously, but stopped reading because it says it's sent to the VITA port (4991) with streaming data, and I see it also as a UDP broadcast to port 4992.
  • Steve-N5AC
    Yes I see that in the code.  I've updated the post to reflect the change.  Thanks
