SmartSDR Client v1.2.1.49 Crash
Hi,
I am running a Flex 6700 with SmartSDR 1.2.1. I had 8 pan adapters with 8 Slices open and was streaming 4 DAX IQ channels at a sample rate of 96000. I also had SDR Bridge open.
The client shutdown without warning (I wasn't 'doing' anything at the time it was just running in the background) so I went in the eventvwr application log and found the following entries:
Hope this help determine the problem.
- Bob,. W1RE
Bob - thanks for the report and the error screen shots. I have entered this into our bug tracker. If there is any additional information you can provide about the reproducibility of the crash, that would be helpful.0
Thanks Tim. I had a couple of these SSDR Client Crashes yesterday. They appear to me to be random - i.e. I wasn't actively changing or doing anything when they occurred - I just had SSDR running in the background and looked up and it had shut down.
I looked for a mini dump file but none was written.
I should mention I am running SSDR 1.2.1 with 8 pans, 8 slices and 4 IQ DAX streams at 96000 bps. So I am running 'full bore' as they say... My computer has plenty of HW resources (both CPU and memory) so that should not be a problem.
Hi Tim,
I just got another 'SmartSDR has stopped working' message. I am attaching a screenshot (it's big). Same as before I wasn't actively doing anything - just letting the 8 pans and slices run).
Please let me know if I can assist in getting you additional info to determine what's wrong.
Does this happen is SDR-Bridge is not running?0
SDR-Bridge does have a connection to the SmartSDR process. It gets to the radio through FlexLib independently. The scenario of running multiple slices, panadapters, and Skimmers does stress the system as a whole.
73 Ed W2RF
and to confirm that thesis - I just had another SmartSDR has stopped responding client crash without SDR Bridge, Skimmer, or any logger running. Just SSDR with 8 open pans and 8 slices & 4 IQDAX streams at 96000 bps.0
My system may be somewhat immune to this sort of problem because I run SmartSDR on one machine (a Surface) and everything else on another (a quad core).
OK. I have added this to the bug report. Thanks for the additional info.0
Tim,
I would like to withdraw this bug report. I had built a new system for SmartSDR and associated apps and found I had a HW issue that appears to be the root cause for this (and a few other) unexplained crashes. I have resolved the HW issues and SmartSDR is now running well with 8 pan adapters and 8 slice receivers, plus SDR Bridge and CW Skimmer without any crashes for several days. I also confirmed it is working on a totally separate system, so I have so I am confident this was a red herring.
- Bob
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
- 456 Remote Operation (SmartLink)
