Remote Operation With The 6300
L.Kubis
Is the ON/OFF power switch on the 6300 of the latching type as on the 3000?
If so once latched ON, can the radio be powered ON and OFF by just cycling the power to the radio as in the case of the 3000?
Hopefully it will do the above enabling simplified Remote operation as the 6300 appears like an ideal radio for this type of application.
Nice work!
Cheers!
Lloyd
VE3ERQ
It has a RCA connector for remote on just like the 6500 and 6700. It requires a contact closure to ground to turn the radio on and off. If you wanted to cycle power to the radio instead you could just short the RCA connector all the time. Remote on is enabled in setup.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
