Audio Monitor – audio after TX band pass filtering preferred
Tony Taddeo
Currently the TX audio monitor provides pre-band pass filtered audio. My suggestion is to provide the TX audio after the band pass filtering, to give you a better indication of TX audio.
This has been addressed previously. The issue is that if the monitor audio is tapped off at the end of the TX signal path, there will be unacceptable latency from the time you speak in the mic to when you hear it in the monitor. So we tap off the audio at a point before the long latency processes (filters) so you do not have the echo on the monitor.0
I know the effect of hearing your delayed audio on your brain. Does make it hard to continue talking normally. I note that the recording function also records pre-band pass filtered audio on Tx. No reason why this couldn't be recorded at the end of the TX signal path as this is for play back reasons ? Perhaps have an option of early or late TX signal path recording for those that want the best audio for on-air retransmit and those that want to monitor TX audio.
Thank you for the explanation.1 -
I'll talk the the engineering guys about changing the TX audio tap off point for recording. I am not sure it can be done easily.0
I use monitor (ACCY jack) for feeding RTA software to another PC, so a bit of latency is of no concern.0
When recording both sides of a QSO, then playing it back, the tx side is way down in volume as compared to the received side of the recording. Hopefully that can be addressed along with the tx audio being sampled at the end of the chain.
Was there ever an answer to this question? Having some way of hearing your TX audio in the monitor is the way it should be done.0
This isn't possible without unacceptable latency. This is explained in the SmartSDR for Windows User's Guide. Essentially it takes too much time to process all of the DSP processing (it is the filters that have the longest signal propagation delay). We provided a way to monitor TX audio using the record and playback feature (also covered in the SmartSDR for Windows User's Guide.1
- 370 Community Topics
- 628 The Flea Market
- 86 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
