No RF output with DAX in v1.2.1
WA6FXT Mike
When I try to TX using DM780 (6.2) or MixW, I see what looks like audio on DAX Control, Transmitter keys; but, no RF. Tried USB and DIGU.
Anybody else seeing this?
F6700, SSB works great. Worked great with v1.1.13
If I turn off DAX (In P/CW) the Mic goes active and I see RF.
2
i had the same problem all look like it was working
but no power out
i reset the radio 6500
Are you remembering to activate TX in both the DAX control panel, and turn on the DAX button in the Transmit panel? If you forget one or the other, then there is a wide trace in the panadapter when FlDigi tries to transmit, but it isn't really a signal, just wideband noise in the TX chain.
If you uninstalled DAX when you upgraded to 1.2.1, then you may need to go back and redefine the audio lines in your Digital Interface programs. While yo are at it, remember to open the properties for each audio channel and set the sampling rate to 16 bit, stereo, 48000.
Same thing yesterday I just closed and reloaded DAX and all was well0
Mike are you still experiencing the problem?0
No it has happen twice this weekend. Both times I closed Dax then restarted it. Everything seemed to work well0
Tim, No, it has gone away and all seems (Well almost) fine. I did have a moment of weirdness, when, after it started working, I couldn't find the DAX control panel. It was not in the usual place. Understand DAX was working, just no control panel. When I tried to start the program from the Start folder, it complained that one was already running. I decided it was time to get some sleep. :^). When I awoke and fired up the next evening, all was well. (Go figure!) 73's Mike0
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 968 Maestro
- 940 Genius Products
