Receive filter
Edward Armstrong-WB2K
When going from lower sideband to upper sideband and back the received filter goes back to factory default it should go back to where it was set..
I would like to see possibly in the next release what you have done with the transmit filter in v 1.21 to the received filter I do not like the wedge it is a lot easier to use the arrows or type in the new received filter like you have done with the transmit filter.
2
I agree, the filter setting/selection persistence per band/mode would be a good thing. I never listen at default 2.7k bandwidth on 75 meters.
Also, if possible, I vote for ability to create customized filters like in PowerSDR by right clicking them and hit Configure.
Dave, wo2x
3
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
