NR on digital
Rick Hadley - W0FG
Loving the upgrade, but one question... The NR no longer seems to be available in DIGU or DIGL. Is this a bug or a feature?
I think that the philosophy is that any noise processing done on data streams is destructive since almost all modems (software or hardware) have their own noise processing algorithms built in. Secondly, noise processin you do in the radio increases latency before the data is passed to the modem so for modes that require low latency, this will exacerbate problems.0
Noise reduction and ANF will adversely affect the decoding of digital mode signals. Technically it is a feature. You want to pass the audio unmolested to the digital mode program for decoding. The same is true on transmit which is why all signal process (PROC & EQ) are disabled in DIGx modes.2
Agreed, I want to know that when I am using digital that all filters intended for voice are turned off.1
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
