Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
Flex 5K Internal Keyer Does Not Work
                    Philip KA4KOE
                    Member  ✭✭
                    I use a 3 wire paddle with my Flex 5000. I noticed that with the recent version 2.7.2, the keyer no longer works. I have confirmed correct wiring of the paddle, cord, and plug. I have tried several combinations under the keyer menu to no success. The paddle acts like a straight key when one side is pressed to common. The other side pressed to common does nothing. However, iambic works partially, but again only on one side. The keyboard Morse function is unaffected.
            The keyer is not broken in PowerSDR v2.7.2. I suspect a configuration issue. In the Setup->DSP-Keyer section, make sure Iambic, Sidetone and Mode B are checked and all other options are un-checked. On the front console when in CW mode, make sure Break-in is checked.0
            I suspect if 2-wire is checked that could cause this.0
            OK, I'll see if this fixes it.0
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 15 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
