cp210x driver and Smart SDR CAT
I use a myMultiProg for progamming Atmel Processors. This uses a Silab CP210x USB Bridge and the Drivers. It worked quite well before I installed SmartSDR CAT, and workes again after deinstalling. SmartSDR CAT installed and connecting the programmer the device Manager says, that the Driver cannot be loaded.  (X64 Driver). Do you have a solution?
Welcome!
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Unless it is a com port number assignment conflict, I am afraid not.  The Silab CP210x USB Bridge, is a virtual com port driver which looks to be conflicting with the virtual comport drivers included with SmartSDR CAT.  We tested interoperbility with the Eltima, VSPManager and Com0Com virtual com port drivers and they work OK with SmartSDR CAT.  If you find a solution, I'd love to know what it is.
  • edited April 2014
    It was a com port conflict. I created a new pair, deleted the conflicting in the device manager. Strange, that after reboot they appeared
  • edited April 2014
    in the device manager again without conflicting the silab chip. Also strange, that the new com port (com5) do not show up in the "main" of the SDR CAT Menu.. But it works now... tnx
