cp210x driver and Smart SDR CAT
Guenter, DK1RI
I use a myMultiProg for progamming Atmel Processors. This uses a Silab CP210x USB Bridge and the Drivers. It worked quite well before I installed SmartSDR CAT, and workes again after deinstalling. SmartSDR CAT installed and connecting the programmer the device Manager says, that the Driver cannot be loaded. (X64 Driver). Do you have a solution?
Unless it is a com port number assignment conflict, I am afraid not. The Silab CP210x USB Bridge, is a virtual com port driver which looks to be conflicting with the virtual comport drivers included with SmartSDR CAT. We tested interoperbility with the Eltima, VSPManager and Com0Com virtual com port drivers and they work OK with SmartSDR CAT. If you find a solution, I'd love to know what it is.0
It was a com port conflict. I created a new pair, deleted the conflicting in the device manager. Strange, that after reboot they appeared
in the device manager again without conflicting the silab chip. Also strange, that the new com port (com5) do not show up in the "main" of the SDR CAT Menu.. But it works now... tnx
- 338 Community Topics
- 579 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
