6500 scratchy audio?
NZ8J
I'm noticing more and more that the receive audio has a "scratchy or clicking" sound when I tune through a signal, both ssb and cw. Normal tuning on a quiet band with no signals is fine, no scratchy sounds, it only happens when I tune across a signal. Once I stop tuning its fine. I'm using a new dell computer running 64 bit windows 8.1 With an I5 processor and 8 gb memory. I have the radio plugged into my wireless router and am connected via wifi to the dell. Everything else operates normally, it's just the audio issue. It doesn't do it all the time, but it does so the majority of the time. I hear it both on the Bose powered speakers and the radio headphone output. I couldn't find anything in the archives specifically addressing this issue. Any ideas? Thanks Tim NZ8J
Try exiting the DAX and bring it up manually if you are using the DAX. If it is direct hardware, I have never had a problem with scratchy audio.
Also, try plugging your computer DIRECTLY into the router. The WiFi is half duplex where direct connect is full duplex and has much faster throughput.0
Thanks for the replies, I connected the computer directly to the router and don't have DAX turned on, still the same symptoms. I'm not quite sure what DAX would have to do with my issue, I only use DAX for RTTY occasionally. I also now notice that on a spot on the band where there are no signals if I quickly adjust the audio level control it sounds exactly like a dirty **** in the speakers and headphones. Adjusting the AGC-T rapidly does not cause the same problem. It seems like when the radio encounters a rapid increase in volume, either by tuning across a strong signal or quickly increasing the audio level by changing the audio control is when I get the scratching or crackling. Any other suggestions to try...? Thanks Tim NZ8J0
I also hear scratchy audio through Bose headphones with v1.1.3 and a 6700. Thought it might be from my RemoteRig configuration, but I've turned off DAX and have a 1Gbps fiber Ethernet connection from the radio to my computer. Will try some direct audio connection tests and report back.
Good morning,
same problem here with my Flex-6500 on Win 8.1 x64 if reduce a AGC-T the problem is minor, I hope a resolution with 1.2 version0 -
Thanks to all for the responses, sounds like it's not just my setup. it's not a huge problem, just irritating and disappointing. Tim NZ8J0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
