Tim - any progress on the CAT serial port driver issue with Win 7?
Wayne Whitman
Hi Wayne
what is the issue?0 -
Wayne - we have made a little progress and depending on your issue, there may be a soultion. I recommend that you submit a support ticket via our HelpDesk (http://helpdesk.flexradio.com) so we can assign you a case number.
For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://support.flexradio.com/ Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue.open a HelpDesk0 -
Hi Neal. Win 7/64 (on my Neal machine) does not recognize serial ports created with SmartCAT. Re-installing SmartSDR and/or SmartCAT does not solve the problem.
What version of smartCAT are you using?0
1.2.4.0
Done Tim - #5742
Wayne, probably something unique. I run Win 7 64 bit (latest versions of both windows and flex) without problem. Use multiple simultaneous serial interfaces for logging freq, s-meter and fldigi.
- 338 Community Topics
- 580 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
