Tim - any progress on the CAT serial port driver issue with Win 7?
Wayne Whitman
Hi Wayne
what is the issue?0 -
Wayne - we have made a little progress and depending on your issue, there may be a soultion. I recommend that you submit a support ticket via our HelpDesk (http://helpdesk.flexradio.com) so we can assign you a case number.
For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://support.flexradio.com/ Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue.open a HelpDesk0 -
Hi Neal. Win 7/64 (on my Neal machine) does not recognize serial ports created with SmartCAT. Re-installing SmartSDR and/or SmartCAT does not solve the problem.
What version of smartCAT are you using?0
1.2.4.0
Done Tim - #5742
Wayne, probably something unique. I run Win 7 64 bit (latest versions of both windows and flex) without problem. Use multiple simultaneous serial interfaces for logging freq, s-meter and fldigi.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
