Tim - any progress on the CAT serial port driver issue with Win 7?
Wayne Whitman
Wayne Whitman Member
edited March 2017 in SmartSDR CAT
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    edited April 2014
    Hi Wayne
    what is the issue?
  • Tim - W4TME
    edited March 2017
    Wayne - we have made a little progress and depending on your issue, there may be a soultion.  I recommend that you submit a support ticket via our HelpDesk (http://helpdesk.flexradio.com) so we can assign you a case number.
    For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://support.flexradio.com/   Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue.open a HelpDesk
  • Wayne Whitman
    edited April 2014
    Hi Neal.  Win 7/64 (on my Neal machine) does not recognize serial ports created with SmartCAT.  Re-installing SmartSDR and/or SmartCAT does not solve the problem.
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    edited April 2014
    What version of smartCAT are you using?
  • Wayne Whitman
    edited April 2014
    1.2.4.0
  • Wayne Whitman
    edited April 2014
    Done Tim - #5742
  • Dave - WB5NHL
    Dave - WB5NHL Member ✭✭
    edited December 2014
    Wayne,  probably something unique.  I run Win 7  64 bit  (latest versions of both windows and flex) without problem. Use multiple simultaneous serial interfaces for logging freq, s-meter and fldigi.
