I propose a modification to how the the TX relays function
Lester Shields
Member ✭
I would like a setting that would activate one of the TX relays with the PTT, but not when TUNE is selected. That would allow sending a low power signal to operate an external tuner, but not key the amp. PTT would work normally.
You do know that when you press the Tune button that is a separate power level? Why not set it for a very low level that gives just a few watts out the amp? Maybe one or two watts.. That should drop the amp output.0
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
