FLEX 6700 relay clicking
KeithE
Some relay inside my new Flex 6700 keeps clicking? Any ideas?
Keith, K5ENS
We'll need more info. What are you doing when it clicks?0
Nothing and everything. As soon as I connect to the radio it starts clicking a relay. All seems to be working fine. I just first started the radio this morning. Running v1.1.3.0 -
Well now it's decided not to connect. After a long calibrating time I get a TIMEOUT and 3 red flashes then a pause on the front panel light.0 -
Did get the 6700 to connect but the relay starts clicking as soon as I connect.
Do a cold boot of the radio, which is to shut down and remove power for several seconds before powering up again. Let me know if that doesn't solve your issue.0
Same thing after re-booting everything.0 -
Sounds like a reset in order and if doesn't work reload software/firmware.0
Didn't work.0 -
Keith - I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
