Help needed, SSDRcat install gets "interrupted error " every time I try to install it.
N4AB
HELP
Run the program with your radio running. I had the same problem and when the radio was running the program installed without incident.0 -
Jim,
Be sure that you have your firewall and anti-virus disabled, and try again.
Thanks Dudley and Jim, since I had already tried reloading, rebooting and the firewall/antivirus programs off, I turned the radio on and gave Jim's suggestion a try and it worked great. So now I'm back on the air.
Only one issue left to figure out. Using cat I created 4 COM ports which all work OK. However they do not show up in "device Manager" even with "show hidden devices" enabled. Anyone have any idea about this problem?
Anyway, thanks again Jim. 73 Al N4AB0
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
