Shutdown process
Greg
I have not seen this posted before so figured I should note this issue.
A couple times lately when I shutdown by pressing the power button I get the SHUTDOWN message on the display but it just hangs there. Eventually it goes away and the radio comes back on with the FLEX-6700 on the display. If I then press the power button again it does not shutdown at all and I have to press it again and then it shuts down quickly.
I saw a similar post a couple of days ago...
https://community.flexradio.com/flexradio/topics/shutdown_issue1 -
Thanks. Similar but different. When my display says SHUTDOWN it hangs there for a long time then cycles back to an operational mode. This only happened two times.0
I am also getting similar results but not all the time. I am wondering if this abnormal shutdown then leads to a high noise floor on the next power up.0
Mark, How often are you seeing a high noise floor, I'm seeing high noise floors on different bands at random. One I reset or jump around different bands I will disappear. Just can't rap my head around the problem yet.0
We will have a fix for the high noise floor issue in the next release of SmartSDR.1
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
