SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.8.0 and the SmartSDR v2.8.0 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
6500 Pan Adapter V 1.1
Transmit on the lower frequency's
Tuning on 15,17,and 10
My 6500 has been fantastic but since downloading the V 1.1 update the band scope goes haywire on transmit on the higher frequency's, all was fine on the previous versions so I am a little confused
any ideas please guys kind regards
Keith
M0PAW..
Also please note that the flex has already tuned on the 10m band and is not in the process of doing so
here is another photo on 10 with me transmitting audio.
I have the same issue on my 6700 when I'm on 15m and up to 6m, and the preamp is on. With 0dB, I don't see it. Tried reverting to the previous beta, and the problem went away. I think it's related to the preamp in 1.1. I've also noticed it takes far less received signal strength for broadband panadapter distortion to occur with the preamp on in V1.1. Keith - AE5XN0
Thanks for your reply Keith hopefully flex will sort out this niggling problem Kind regards Keith M0PAW0
Thought I'd post pics of my 6700 panadapter in SSDR V1.1 while hitting TUNE @ 10W into a dummy load on 21.430MHz in USB mode with various RF gain settings to show how this issue gets worse as the receive pre-amp gain is increased:
First is with 0dB RF Gain:
Now with 10dB RF Gain:
Now with 20dB RF Gain:
Finally, at 30dB RF Gain (note I had to change the Y-axis reference here):
I don't see this happen if I try the same thing the previous SSDR V1.0.24.
Keith - AE5XN0 -
Thanks again Keith I have just done the same tests as you and mine is also the same, I just hope I am not putting out any spurious emissions of any type..0
This is because you have a very sensitive receiver in the same box with high RF currents. What you see is not going over the air. We have verified this on external spectrum analyzes. The more you turn up the gain, the more it will cause those artifacts in the receiver.0
Gerald,
There is something different with V1.1 that is causing more IMD distortion in the receive path than there was with previous versions of SmartSDR. I don't know what it is, but it's noticeably much worse in V1.1 than it was in V1.0.24 and before.
Here are screen captures on my same 6700, but taken with V1.0.24 Beta. Note there is much less IMD distortion in these plots compared to my previous post with V1.1. This is still using the TUNE function on USB with 10W into a 50ohm dummy load, the only difference is the version of SmartSDR I'm running.
0dB RF Gain with V1.0.24 Beta:
10dB RF Gain with V1.024 Beta:
20dB RF Gain with V1.024 Beta:
30dB RF Gain with V1.024 Beta:
You can see that V1.0.24 looked much better, even with the 30dB setting!
Keith - AE5XN
I believe what you are seeing is an overload occurring at a lower level than in previous software versions. We are aware of the problem and are working to fix it. Honestly, we didn't expect hams to find the problem because it takes a very strong signal to make this happen, but your local transmitter qualifies. This is happening in the receiver and it is software related, not hardware, and it doesn't affect your transmitter output.
Steve0 -
Steve,
Thanks, yes, I can also confirm this is NOT on the transmit side, it's some non-linearity that got introduced in V1.1 only on the receive side.
I live in an area with a lot of local hams, and I've even observed a signal from one as high as -19dBm on the S-meter on 3.890MHz AM, and even this level just obliterates my 6700 with V1.1 when the 30dB pre-amp is engaged while I'm working 10m with multiple panadapters on different bands.
Just this evening, with 8 panadapters running on 80m, 40m, 20m, 17m, 15m, 12m, 10m and 6m, and the +30dB preamp engaged, I had a nearby signal peaking in the -40dBm range on 7.279MHz that was causing "scratching" and broad-band panadapter "pumping" until I reduced the RF gain. Never had that happen with V1.0.24 and below.
I use the 30dB preamp on the higher bands extensively, since I'm only running a Butternut HF9V vertical on a postage-stamp city lot in the N. Dallas suburbs, so the combination of the number of nearby hams and my use of the preamp made me an ideal candidate to pinpoint this.
Keith - AE5XN0 -
OK Keith it sounds like this is the problem. With 30dB of gain, the radio in its current software configuration will overload about -26dBm. So -19dBm is 7dB over the overload point -- again with 30dB of preamp gain.
My suspicion is that you really don't need 30dB gain on 10m. If you can look at a weak CW signal and then increase the preamp, see if it helps hear it better with each click. If your local noise level is extremely low or you antenna has negative gain, it may help, but I suspect on 10m you probably only need 10dB, maybe 20. Using a preamp when you don't need it will make things worse -- it will hurt your IP3, lower your overload and increase noise.0 -
Thanks for all the information guys I may jump back on to V1.024 for the time being until this little issue has been sorted out as any high local interference or strong tuning from stations is sending the pan adapter into slight overload.
Kind regards
Keith
M0PAW0 -
Steve,
You're right - I'm really over-using the pre-amp at 30dB on 10m, especially with so many local strong signals I frequently encounter. I think the incredible dynamic range of this radio had me spoofed into thinking I could get by with it. I do look forward to getting more of that dynamic range back in future releases :-).
Thanks also for letting us know that the overload on V1.1 is -26dBm. I'll know now to keep the pre-amp gain combined with the received signal strength less than that to stay out of trouble with V1.1.
Keith - AE5XN0 -
Just to be clear, the overload point in v1.1 is ~ +4dBm. If you insert 30dB of gain in front of that, it becomes ~ -26dBm.0
- 18.7K All Categories
- 141 Community Topics
- 2K New Ideas
- 297 The Flea Market
- 6.3K Software
- 5.4K SmartSDR for Windows
- 95 SmartSDR for Maestro and M models
- 218 SmartSDR for Mac
- 188 SmartSDR for iOS
- 181 SmartSDR CAT
- 116 DAX
- 321 SmartSDR API
- 7.9K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 637 Maestro
- 30 FlexControl
- 781 FLEX Series (Legacy) Radios
- 436 Genius Products
- 254 Power Genius XL Amplifier
- 158 Tuner Genius XL
- 24 Antenna Genius
- 126 Shack Infrastructure
- 81 Networking
- 216 Remote Operation (SmartLink)
- 94 Contesting
- 320 Peripherals & Station Integration
- 89 Amateur Radio Interests
- 602 Third-Party Software
