Jt65 does not always return to receive after xmit or tune from the app
Reggie-k6xr
using jt65. after transmitting or tuning, xmit does not always return to receive. sometimes it does and sometimes it does not. Any thoughts? Thanks
Is it hung in actual transmit or just not hearing a receive signal? If hung in transmit, think it might be RF hanging it in transmit? Maybe try it into a dummy load or lower the power and just it .. Dudley0
Which program are you using? I've used WSJT-X and WSPR-X and neither have this issue that I've seen.0
Running 5 watts. WSPR works great. Fldigi at 30 watts and psk31 work great. J565 will go into xmit and return to xmit but the audio scale still shows modulation. I have downloaded and installed several times from the link provided by Tim. I have now deleted ssdr/cat and all those programs. will install again today and see how it goes. Again, straight wspr works great0
OK if you continue to have issues, let us know. A screen shot is generally a good way to see what's going on.0
Ok tnx0
I may have the incorrect version.......0
when running WSPR-X now. I can send and receive but on returning to receive, the dax/mic level indicator does not stop indicating output although I am clearly in receive mode. sometimes the led bar just seems to hang there and at other times just one little bar stays. I can dismiss them by clicking tune button on and off. It shows a level although I am in receive mode and receiving data! same thing in jt65.0
The meter operation in DAX has been fixed and will be in v1.10
- 390 Community Topics
- 661 The Flea Market
- 54 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
