Audio Volume changes
DonS
Member ✭✭✭
I have three slices open. Slice A is opened and set to 7035 digu, Slice B is opened and set to 7191 lsb, and Slice C is opened and is set to 3575 cw. When either Slice B or C is TX active, i.e. TX enabled, volume is normal, however, when I make Slice A active volume drops. It has been discussed here about decreased audio because the audio is shared but I don't understand why two of the slices (B & C) the audio is fine while the third slice the audio level decreases when made active for TX. If I have all three slices on 40m I still encounter the same situation. It doesn't make any difference as to which slice is active (yellow or green upside down triangle). What am I missing?
I have the same issue. When using two slices. Separate DAX channels for each slice. The audio drops on the slice set as Slice A when Slice B is set to Active TX. Also, the DAX channel on A changes to NONE when Slice B is enabled. I have to open DAX and reset on each slice.. I will watch this Question to see the answer.0
Don - I have changed your question topic to a problem and entered it into our bus tracker for further investigation. Thanks for the report.0
Thanks for the confirming report.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
