RF Power indication to allow Final output power readings
philip.theis
I know there are many things on the list before this, but it's fun to dream. How about a provision with the RF Power indicator to get information from the amplifier, or a sensor after the amplifier so that the readout indicates your final output power and SWR readings. Perhaps the easiest way to pull this off is an external network device that has input and output RF connectors and an RJ45; then the radio does the rest. Phil K3TUF
I do this already using a Wavenode WN-2d SWR Device which supports up to 4 sensors. www.wavenode.com0
Oh, I've had Wavenode, and now have a set of W2's from Ecft. But it would be nice to see it on SSDR0
Wave node rocks. I run the Wn1 because of the rate it samples. So good I bought 3 of them . I have sensor after the flex and after the Alpha 8410. Have more sensors incase of extra transceivers. Works great with remote operation controlling amp and antenna switch.0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 876 Genius Products
- 315 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
