Slice / RX Issue
DonS
Member ✭✭✭
I start out with a single slice and single RX (A). I open another slice and a second RX (B) automatically opens up in the first slice and when I open a RX on the second slice it opens as (C) - I would expect that what I don't expect is the second RX opening on the first slice. When I close down the second slice TX (C) closes as expected and RX (B) on the first slice closes.
I have seen this issue as well and documented it. I think that this is an issue with the beta version that will be cleared up in the release version of SmartSDR.1
If I open a third slice then the first slice gets a third RX (C) and if I carry it out to adding a fourth slice then a fourth RX(D) is added to the first slice. Strange behavior.0
- 392 Community Topics
- 665 The Flea Market
- 172 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 214 DAX
- 387 SmartSDR API
- 69 Aurora
- 310 FLEX-8000 Signature Series
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
