The best way to start 2014
Ali 9K2WA
I received my Flex-6700 on the first week of October 2013, I have been enjoying it ever since, with every update my confidence, admiration and excitement has never stopped. Now that I have installed SSDR beta 1.0.24 with DAX, and finally got HRD to work over the new year's holiday, I can say SSB and Digi modes operations will never be the same again, the Audio quality of the Digital Audio Exchange defines excellence. Thank you folks for a job well done, Keep up with the excellent efforts.
Ali How did you get HDR's digital master to transmit, it receives OK but I can not get it to transmit, it looks like it's working on the waterfall, but the Flexradio is not activated, I have tried every option in the PTT option panel of Digital Master. Thanks, W0QKL0
W0QKL I have been running HRD 6.1 and DM780 with my 6500 using DAX. Previously without DAX I used the navigator interface through the FLEX ACC. HRD DM780 is configured in the Soundcard tab for DAX Audio TX1 and DAX Audio RX1 to Transmit or Receive. Also, DM780 is looking for the FLEX PTT line configured in the DM780 PTT Tab and configured in CAT. This Com port will key the FLEX. My DM780 is configured for Com 7 in the PTT tab. Com 7 is predefined in FLEX CAT as PTT with RTS. Open the CAT window to verify the Com port settings. 73's W4EY0
W4EY Thanks got it going, I overlooked the PTT in the Cat program, thanks for jogging what little gray matter I have left. W0QKL0
Here are the steps for having HRD/DM780 working with DAX: 1. reboot your system and Start SSDR, SmartCAT. 2. Remove any VAC programs that are running like DDutil etc. you dont need them. 3. In my case I had to Exit DAX from the try if it was running. (I created a shortcut icon on my desktop) 4. Create a SmartCAT virtual com port with DTR/RTS activated. 5. Start DAX 6. Start HRD, and make sure that HRD does not auto start any program other than DM780. You can start LogBook later you will need it for DM780 afterwards to update your logbook from its RX screen by right clicking on the QSO contact call sign, and/or other missing info on other fields. 7. From DM780 Tools -> Program options select PTT then chose the PTT COM port you have created In SmartCAT. Last night while I was waiting during a tremendous heavy pileup for 1A0KM to listen to stations outside Europ working split on 40 meters, I was also chasing DX on a second Slice for DAX, All what I had to do is change TX to 1A0KM listening frequency on the SSB slice. Its a good way to start a simple yet very efficient wireless SOR operation. Note : I did not use the Flex ACC, nor any physical I/O audio cables, it is absolutely TCP/IP through the Ethernet connection. That's all folks, enjoy. Ali Alwazzan - 9K2WA - Kuwait0
Many thanks to Ali and W4EY! I ran into the same issue and finally created a com PTT port in Smart CAT as you advised and we're transmitting with PTT now. What threw me off was that in the HRD main window (radio control) the "TX" button keys the 6500 - so I was trying to figure out why DM780 did not send a PTT signal through to HRD and then to the 6500 (still a mistry). Now if I can only figure out why receive PSK text is not clearly printing, I'll be good to go. Community post >> http://gsfn.us/t/4ef5s0
Thank you Bill for the CW QSO on 20 this morning... I heard you mention you had a Flex radio and intrigued me to check who it was... LOL 73 and I LoTW you also ..0
Ernest: It was fun to CW QSO between two FLEX users. The internal FLEX keyer takes getting use to when running CW Contest. Wish FLEX would move the CW Macros up their software development list. I input to LOTW at the end of the Months. 73's and Have a Blessed Day. Bill W4EY0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9.1K Radios and Accessories
- 14 Aurora
- 152 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 866 Genius Products
- 445 Power Genius XL Amplifier
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 717 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 939 Third-Party Software
