Selecting 2M shuts down the 6700
Stan VA7NF
Member ✭✭✭
Selecting the 2M band immediately disables the 6700. SSDR reports the disconnect and removes the radio from the selection list. One minute later it reappears. Repeatable.
What version of software are you running? Also what is your panadapter / slice configuration when this problem occurs?0
Software: SSDR 1.0.24, nothing else started Process: Turn on 6700 and connect to SSDR (Comes up on 20M with no receivers) +RX and get a receiver on 14.008 USB Select BAND -> 2M and get the disconnected message It is repeatable without selecting +RX; just BAND->2M I believe the last operation was to use AM slope detection on FM signals (works but with horrible audio)0
Try resetting your persistence database by pressing the OK button when you power on the radio with the front panel power button. Does it happen now?0
The power on reset corrected the problem.1
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
