Audio Level with DAX and Xmit keying
Nick
PSK with DAX. I'm using MULTIPSK with DAX. I followed the YouTube and have a couple of questions. I have to run the DAX receive gain full scale to get a receive level of about 50% on the MULTIPSK signal indicator. Anything less than full scale drops the level in MULTIPSK to below 20%. This works but I am concerned about having to run the gain so high. Has anyone else seen this behavior in other PSK S/W? Also, in the video going into the transmit mode on the PSK S/W seamed to put the radio in TX mode. For me to transmit I have to put the 6500 into transmit mode with the MOX button and then hit transmit on PSK S/W. Did I miss a setting somewhere? Tnx, Nick
You probably need to set up the MULTIPSK program to trigger the PTT via serial port provided by SmartCAT.1
- 654 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
