DAX control
Is it possible to have the corresponding DAX channels open automatically in the control panel when the slice DAX control panel is used to select the channel. Also, will it be possible to activate more than one DAX channel per slice? It may be useful to open an IQ channel and an audio channel for the same slice. Thanks and HNY Greg AB7R
I'm not sure I understand your first question. When you click the channel number in the DAX control panel, it starts the flow of receiver data (provided it is paired with a slice receiver). The DAX control panel remembers this so next time you restart, it is running again. There can only be a single DAX channel per slice receiver. You may, however, have multiple clients connected to the channel. Not entirely sure why you would want to do this yet, but it is enabled in the software. So you can have PC#1 listening to DAX channel 1 and PC#2 listening to DAX channel 1 also. Finally, DAXIQ channels are independent from DAX channels. DAX channels are associated with slice receivers, but DAXIQ channels are associated with panadapters. You will select a DAXIQ channel on a panadapter and then the center of the panadapter will be the center of the IQ data received over a DAXIQ channel. If you tune the panadapter, you will tune the DAXIQ channel also. As of today, this functionality has not been released. It is scheduled for release with SmartSDR v1.1.0
Hi Steve! Thanks for the info. As for the first part of the question, I was wondering if it were possible to select the DAX channels from the slice control....and that action in turn automatically selects the corresponding slice rx/tx in the DAX CP. Just an automation step. CUL greg0
The settings on the DAX control panel are not remembered as i switch off SSDR. Next time i start SSDR only DAX channel 1 is enabled. I had to open the control panel and enable the other channels i wanted to use.
Steve, I think the second question might be, a request to be able to have two different applications connected to the same slice at the same time. For example, can I have fldigi connected to decode CW while also using Audacity to record my contacts for later review... Or have a USB mike connected via DAX 1 and my voice keyer connected to the same slice via DAX 2? Is this what you are getting at, Greg?0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
