SmartCAT update
Greg
Thanks for the SmartCAT update. I use DXLabs and Commander has a set of buttons that when clicked will create slice B and set split based on the button presses (1,2,5 or 10 kHz) and make slice B the TX slice. Before the update no matter which button I pressed slice B would be set to 5 kHz above slice A. This was also tru for clicking a spot with QSX info. The spot may indicate up 1.5 but slice B would always open at +5. With this update it now sets slice B correctly. I originally thought it was a DXLabs issue but this update fixed it. Thanks! 73 Greg AB7R
I think you are referring to the USER DEFINED COMMANDS? Would you mine either sending me one or uploading to the DXL files group. I'd like to see your command structure. I have a set of UDC's for cw, psk, rtty, jt, and phone tweaked for the Flex5K Haven't created a set for the 6K as yet. pse and tu de w9ol0
Hi Bill. No, this is not related to the user commands. Look at the VFO B window to the right of the VFO A display. Just above the VFO B window you will see the buttons already there. When you click on either one it will create slice B and make it the TX slice and set the split based on which button you click. 73 Greg0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
