Want to install SmartSDR CAT for my 6500
Vern
During the initial install of the 6500 I believe I elected NOT to install the CAT program - if that was possible. Now I do. Can not find the software to do it. Ready for DAX things. Using Win 7. In 'Add or Remove Programs' there is no listing of the program. Hints?
Search for "SmartSDR CAT Setup" also read the CAT install guide from http://support.flexradio.com/Downloads.aspx0
If you elected to NOT install CAT when installed 1.0.24 ... First look in the Windows START>Programs>Flex Radios systems>SmartSDR Beta 1.0.24 for SmartSDR CAT Setup... If its not there then I would recommend that you rerun the SmartSDR 1.0.2.4 Beta installer Which should install the CAT setup. I don't know of any problem running the SSDR installer twice. The firmware is already on the radio so you should not have to go through that step.. Follow the CAT setup instructions explicitly from the release notes. AL, K0VM0
First to DRAX: I found and installed the wanted software. Thank you. AL: I see all the things you mention in the "Windows START>Programs>Flex Radios systems>SmartSDR Beta 1.0.24". I am going to hold doing what you suggested. I first start the 6500 followed by starting the CAT pgm. When I click the icon in the task bar the 'Main' is selected. Available Radios list just the 6500 but the 'Connect 3rd Party Program To Port: list nothing! Clicking the down arrow in that same window it list nothing. I suspect there is should be a list of DAX's if noting else. Or maybe a list of COMx ports. Any clue? Vern0
With the help of a friend who is thinking of buying a 6500 we got the thing running using FLDigi. FLDigi was getting frequency, the button with "QSY" on it (off center in the bottom status bar) came alive but about as sudden as we got it running it quite. Still working on it. Will accept hints. Vern1
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 967 Maestro
- 940 Genius Products
