DAX Control Panel v1.0.2.22
Ernest - W4EG
KF2T George F6.5K, Fldigi, Win8. W4EG (me) tried to get my F6.7K, HRD v6.1.4.189 build 3798, Win7 to populate the Audio Stream, I tried all the possible settings with HRD and WSJT and none worked. I have handshake with HRD PTT and the Rig control appears to be working. No RF appears when I enable the transmitter and there is no audio integrating the received band activity area.
Note that his on slice 1 is properly id as "Slice A" "Rate 1565" - KF2T photo
W4EG no matter how I configured DAX it never change. Also, I noticed that the DAX Control Panel would not appear in the lower right task bar. I had to install it from C:Program FilesFlexRadio SystemSmartSDR beta_v1.0.24DAXDAXWPF And the answer is NO it was not in All ProgramFlexRadio System folder either. It took 3 download to get it to work. On the first 2 DAX download it was a no show and no run . One head I could say "I did not read the instructions but two; I kind it doubt it" I am on hold with DAX until this is resolve.
Did you select DAX channel 1 in the slice you are trying to listen to?0
Also let me know if you have more than one radio on your network0
Hi Steve, Sold all the PDSR radios. I only have the one F6.7GPSDO LE. Dedicated computer and no other device not related to SmartSDR. KF2T and I tried connecting to 1 in the beginning. We tried so many times and nothing happened. Then we switched many times to other slices with similar results. I performed a radio reset; no change. I just got home and will try this afternoon and see what happens before I summit a report to have FRS take a look at it.0
Ernest - W4EG: Is this still a problem?0
No Tim... KF2T George in Vegas helped me solved the problem. (failed to read TIM) Thank you for asking. (For those in Rio Linda TIM = The Instruction Manual)0
Great! Thanks for letting me know.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
