WIDE Bandpass indication still has a bug
K1UO Larry
Member ✭✭✭
Using DAX on remote computer. Opened slice 1 on 160M with bandspread 1810-1830 no wide bandpass showing.. opened a second slice and Panadapter for 80 meters with the Bandpass set from 3500 to 3513... what happens is this then sets both slice panadapters to the WIDE mode. and I cant change this until I dump the second slice/panadapter. Also getting occasional thumps/bumps in the DAX audio.
On 80 meters LSB Panadapter is always on wide. I have closed and opened and also rebooted and it always comes up wide. 60 meters also comes up wide but the other bands do not.0
I suspect this isn't a bug. Unless both panadapters are physically on different SCUs which would require separate antennas, the WIDE indicator will show up since there is only one preselector filter band for both 80 and 160m. How are you observing the audio issue with DAX?0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
