Is 2 Meter Transmit on the 6700 not yet implemented?
W5UN_Dave
I tried transmitting SSB on 2 meters with my 6700, but see no output. Is 2 meter transmit not yet activated on the 6700? Does anyone produce an amplifier needed to boost the low output up to, say, 50 watts or so??
3
Since FM is not listed until the end of the road map, I think that we will be seeing a lot of other new features first.0
At 2 Meter I could see +7 dBm on the XVTR output. So You need some 40 dB lineair PA. For RX on 2 Meter You would also need some 20 to 30 dB peamp. pa0bie0
Robert, I have no interest in FM at all, only CW ad SSB (for the digital mode WSJT) for EME operation0
From what I understand, the 6700 doesn't have a PA stage for 2 (or 4) meters. Thus, only the "transverter" output is available for use. The receiver should be fine, though. Can you hear well on 2m ssb now?0
- 374 Community Topics
- 101 SmartSDR+
- 425 SmartSDR for Mac
- 54 FlexControl
- 999 Third-Party Software
