Fan Control
Can there be a way for the operator to manually control the 6000 series fans? When doing some casual RTTY this weekend running about 60W it did not take long for the rig to get to over 70 degrees C....then to 80. The fans were humming away but did not seem to do much in keeping the temps down. 80-C is pretty hot. If we can set the fans to be on all the time at a bit lower level than full speed it may go a long way to keeping the temps down. I was not rag chewing when the temps got so hot...just a normal QSO. 73 Greg AB7R
Odd... my 6500 sits 4" away from a legal limit amp and it doesn't get that hot. Are both sides open so that air can be directed through the chassis? Mickey N4MB0
Yes...plenty of ventilation room. It is only doing this in digital modes like RTTY and when transmitting for a bit over a minute or so. I can see the temp rise on the DDUtil display from 30...40...50...76...80. Then cools down to about 50 before I transmit again. -Greg0
guess i would be in trouble as i always run 100w on the flex 3000 the high I have seen 70c0
Maybe a silly question, but can you confirm the radio is "really" getting hot? With an internal 80 degrees, there should be heat pouring off the unit. Could this be a software issue? I do a lot of digital mode work and unless I'm (accidentally!) working into a mismatch, the fans always stay at the lower speed. I also don't use DDUtil --possible connection there?2
your buddy in the left coast... Still waiting for DAX0
The two side fans are indeed **** air and the exhaust is very warm out of the rear vents. I submitted a help desk ticket for this though I am not sure if it is a problem....I don't know what the duty cycle is or if the power should be reduced significantly in a key down mode like RTTY. 73 Greg0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
