Utilizing DDUtil with 6500 to operate Tokyo Hy-Power Amp. and Tuner
Alan --- N5MSE
I'm trying to get my 6500 to activate my Tokyo Hy-Power Amp and Tuner using DDUtil. v.3. automatically. I'm using the same setup that has worked for me on my 5000 for over a year. Changing the serial cable to the 6500 computer and setting up DDUtil as required and when I change bands it will not activate the Amp. or Tuner. Is there still a problem with the CAT or am I doing something wrong?
You will need to set those devices like you did with the 5000, the physical port numbers in the appropriate option window.0
I have used the new (made for 6000) DDUTIL version with a THP amp successfully. DDUTIL 3 has a "legacy" option for the 5000 and others. I used DDUTIL 3 version 1.44. The "old" version of DDUTIL doesn't connect to the 6000 via a comm port the way the older DDUTIL did. Ned, K1NJ0
Ok. Here's my setup in DDUtil V.3.0.06. At the Setup tab I have signature selected and the DDUtil sees my radio, ser #, IP add. etc. My SmartCAT Port is Com 7, so on the Ports tab. In RCP1 I select COM 7 and check the B Cast. Still doesn't work, what am I missing?0
Under the "ports" tab, I use "passive listener" and assign a physical port. The THP amp seems to like the 9600,n,8,1 setting. It works with or without follow PSDR checked. This is very much like what I do with the '5000 as well. Ned, K1NJ1
Ned: Thank you so much for the information. I was missing that one little thing. My USB cable is assigned COMM 4. I put that in the port under Passive Listener with 9600-8-N-1 selected. I also had to select under **** Radio, Follow PSDR and select the Kenwood option. It works great. I knew it should work as well as the 5K did, I just couldn't get the right combination. 73, Alan N5MSE0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
