Tha charm of the needle.......
Beppe IK3VIG
Hi, playing with my toys and CAT software to add a second tuning knob and a needle reading. On "SLICE A" TmatePLUS tunes and reads the S-meter, PTT pressing a button. At today PWR/SWR/ALC values are not available from SSDR CAT, also others functions under "F" buttons are not implemented, "SLICE B" with FlexControl.knob. TmatePLUS works directly connected to SSDR CAT port or as DDUTIL/RCP. 73 Beppe
As much as a dislike analog meters... that is still much more readable than the invisible bars on SSDR I see the download link is: http://www.woodboxradio.com/tmateplus.html0
Hi, standard TmatePLUS works with traditional PowerSDR, by limited time of 15 days, after it requires a license (generated on radio serial number). It can works with SSDR in demo mode for limited time, after it requires a Tmate knob to work. At today SSDR CAT does not reply with PWR - SWR - ALC values, so TmatePLUS is not full working as with PowerSDR. I'm working on a freeware S-meter for SSDR, it will be available this week. 73 Beppe ik3vig0
Thanks for the update Beppe!0
Hi, waiting the analog S-meter designed for SmartSDR, you can play with my freeware well knowed BobSmeter-Flex, download available here: http://www.woodboxradio.com/freeware.html Simply set the CAT port to SmartCAT assigned port and press start, now you have the classic S-meter for "Slice A". 73 Beppe ik3vig0
- 633 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 928 Genius Products
- 339 Tuner Genius XL
