Slice controls unstable
Greg
Running 1.05 on the 6700. Two pans open and three slices, two on top and one on bottom. The controls for Slice A are only half working. I can reduce settings but not increase them. I can drag the slice volume lower but not higher; clicking to the right of the circle in the slider sometimes brings down the mode options. Also cannot bring the balance control to the right or the AGC threshold. If I click on the circle on the threshold I get the default AGC choices of fast medium or slow. THe other slice controls work fine. 73 Greg
I experienced some intermittent issues relating to the "filter box" moving from right to left by itself and could not select different filter settings (on the original slice). 3 slices active. I restarted SmartSDR and all was normal. No problem since.0
Closing the slice and opening another resumed normal behavior. No big deal but something caused it to happen.1
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
