Spot Button would be helpful
W5UN_Dave
W5UN_Dave Member ✭✭
edited June 2020 in New Ideas
A momentary spot button that sounds the pitch tone while the mouse button is depressed on it would be helpful on CW. I need this to precisely line up a signal frequency when using the 50 hz filter
2 votes
In Review · Last Updated
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    You may have already found this, but if you turn "Break-in" off, and hit the key, you will get ae side tone. You will also see a "pip" on the screen at the location of your CW signal. It isn't as easy as a spot button, but it works.
  • Greg
    Greg Member ✭✭
    edited June 2020
    SPOT auto tune like in the 5K would be even better. Why not make a spot button to center whatever signal is in the filter passband....any mode? And....say you are tuning around and you see a RTTY signal. Click on it.....but the radio is not tuned so that the signal is tuned to the filter. So you have to guess where to tune so that the signal is in the filter passband. This should be automatic. 73 Greg
  • Ken - NM9P
    edited December 2016
    I almost forgot about the "auto zero" on my 1500. I haven't used the 1500 in so long since I got my 6500. That was a nice feature I would like to see implemented in SSDR.
