DXLab,SSDR v1.0.5 and CAT v1.2
Brad - N6SPM
6500, Windoze 7, SSDR 1.0.5 and CAT 1.2. Latest DXLab Commander and Spot Collector. Noticing a new behavior. When I QSY to another band by clicking on a Spot in Spot Collector, the Slice goes there, but not the PAN and I get a WIDE indication. This is the same as before. However, when I then click on the arrow at the edge of the pan (with the new slice freq), after the PAN moves there, the WIDE indication stays displayed and I can't get rid of it without closing SSDR. Operator error? Can anyone confirm? Suggestions? Thanks Brad - N6SPM
Brad, this behavior is known & being worked on. By-the-way, you do not have to close the SmartSDR client. Simply close the panadapter & create a new one. 73, Ray, K9DUR2
Thank you Ray. Are the bandpass (pre-selector) filters switching in and out OK? I guess what I mean... is this a display issue or does it impact the front-end filtering? I was under the impression, possibly wrongly, that when Wide was displayed, the pre-selector filters were not engaged. 73 Brad - N6SPM0
Brad, They are still investigation that. There is some indication that it may only be a problem with the WIDE indicator, but that has not been determined yet. 73, Ray, K9DUR1
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
