Comp does not work correctly in new beta version 1.0.5
COMP does not seem to operate as it did on earlier version. I have to viturally yell to get comp meter to move. It is hardley able to adjust. V.1.0.5 beta.
Welcome!
  • Member ✭✭✭
    edited June 2020
    I noticed this first off. I have full scale (0 dB) mike output on BAL with my PR22, but can't get more than about 5 dB compression even with the slider at full 100%. I also have to turn the mike up a little higher to get full mike level out. In the case of the PR22UT, I now must have it at 100% when 90% used to be enough in v. 1.0.
  • Member ✭✭
    edited January 2017
    I noticed the compressor meter does not move on the beta version. I am talking to K5UX with his new 6500 and he is using 1.0.0 and the compression meter is working and mine is not.
  • Member
    edited April 2016
    I can't get the compression needle to move either. I had the F5k listening and looking at the true output (feeding dummy load) and I can see some compression activity is actually occurring. Also was able to confirm about 10db or a little more of downward expansion. If we had a bit more (like another 20db?) of mike gain and a better definition of just where the thresholds for compression/expansion were set it would be easier to accurately critique the performance.
