Number Of Panadapters
Travis Best
Currently I am only able to turn on 3 Panadapters am I missing something that I should of read in the release notes because I thought right now I should be able to do 4??
Hi Travis, I went back to some of your previous postings to determine which radio you have and I see it is the 6700. Is it with the latest Beta release V1.0.5 that you are having trouble opening 4 Panadapters? Just tried it here and all seems fine. I was having problems with weird events at first but all ok after rebooting the computer. I think this should be done first before connecting the new version of SSDR and must be done before using the new SCAT.0
Yes it is a 6700 I have had this issue on 1.0 and 1.0.5 I can make 4 RX slices but not 4 panadapters the 4th panadapter shows nothing and I can't add a slice to it0
I have the same issue with my 6700.0
V1.0.5 I can create 4 panadapters without issue on my 6700.0
I believe that I had that problem until I purchased a graphics card for my computer. Prior to that, graphics processing was done by the computer CPU and memory.0
I can create four panadaptors, however, I can only three slices. I started at 40m and one slice, then I created a second panadaptor with one slice on 20 m. I created a third panadaptor with one slice on 15m with one slice. I then created the fourth panadaptor on 10m, however, the "+RX" was greyed out. Running the 6700 with SSDR 1.05 and SCAT 1.20 on an iMAC 27" using Parallels v9 and windows 7 pro.0
I have converted this Question topic to a Problem post and transferred it to the HelpDesk. If you are experiencing issues of this nature, please submit a HelpDesk support ticket (using the Zendesk link on the front page of the community in the right side bar)0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
